The following is an example setup configuration of FreeRADIUS as a RADIUS TLS server.
Edit the following CA config
file (ca.cnf) to have key usage:
/etc/freeradius/3.0/certs (otherwise /etc/raddb/certs)
[v3_ca]
subjectKeyIdentifier = hash
authorityKeyIdentifier = keyid:always,issuer:always
basicConstraints = critical,CA:true
#crlDistributionPoints = URI:http://www.example.org/example_ca.crl
keyUsage = cRLSign, keyCertSign, digitalSignature
extendedKeyUsage = OCSP Signing
noCheck = yes
ExtremeXOS requires key usage for a CA certificate.
Edit the file /etc/freeradius/3.0/certs/xpextensions with
the OCSP server address:
[ xpserver_ext] extendedKeyUsage = 1.3.6.1.5.5.7.3.1
authorityKeyIdentifier = keyid,issuer
authorityInfoAccess = OCSP;URI:http://10.127.2.236:2561
Use the IP of the machine
in which the OCSP server runs. It can be the same machine where FreeRADIUS
runs. DNS can also be used instead of the IP.
Run the OCSP server using the following command in the same path where the
certificates and index.txt are present:
openssl ocsp -port 2561 -text -index index.txt -CA ca.pem -rkey ca.key -rsigner ca.pem
Clean up by entering make destroycerts.
Create the RADIUS TLS server key and certificate by entering make
server.pem
Create the ExtremeXOS switch key and certificate by
entering make client.pem.
Create the DH by entering make dh.
Enable TLS in FreeRADIUS:
File:
etc/freeradius/3.0/sites-available/tls
If you do not want the
RADIUS server authenticating ExtremeXOS,
search for the previous command line and set require_client_cert=
no.
Search for 'clients
radsec' and add the ExtremeXOS
switch IP:
clients radsec {
client 10.127.2.19 {
ipaddr = 10.127.2.19
proto = tls
secret = radsec
Add a soft link for
etc/freeradius/3.0/sites-available/tls at
etc/freeradius/3.0/sites-available/tls by running ln -s
<file>.
Restart FreeRADIUS (or
radiusd).
EXOS Switch Setup:
Copy the ca.pem to the TFTP server.
Copy the client.pem to the TFTP server.
Convert the private, encrypted client key to plain format:
openssl rsa -in client.key -out clientPlain.key
Copy the clientPlain.key to the TFTP server.
Install the following to the switch:
Download the ca.pem as a trusted ca in the switch
by entering download ssl <ip> certificate trusted-ca
<file>
Download the client.pem as an ssl-cert in the
switch by entering download ssl <ip> certificate ssl-cert
<file>
Download the clientPlain.key as priv-key in the
switch by entering download ssl <ip> privkey
<file>
Configure RADIUS or RADIUS-accounting with the TLS option.
